Issues W/Gimbal Calibration
Even after recalibrating the gamble it seems to be off.
When flying straight, it always seems as if the drone is 15 degrees off on its heading... Thoughts?
Hard to tell in photo but it always seems to aim a little to the right, assuming you are facing the front of the camera
Do the gimble calibration with the bird tipped backwards so it's resting on the two back wings and the landing gear and the do it again normal. That should fix it
Reactions: svjobeth
hey it seemed to work some, however it came back a little a few days later - however I cannot be sure it wasn't just the wind... going to check again once weather gets better
I have the same problem, tried the recalibrate process, the camera was straight after the calibration with the P4P leaned back on its motors. Then it reverted back to crooked when I calibrated it level. Is the second calibration necessary?
my camera will do this when I apply a stored camera setting preset..whether its a still camera or video camera. I no longer use the presets.
axipap
