Is this an aftermarket antenna set up?
I bought a used P3S recently and it works/flies very well but only gets to about 800' before I start getting the "weak signal" alert. I'm wondering if this is the standard antenna setup or an aftermarket one and if there is anything I can do to make it get a better signal?
Yes they are aftermarket ones and never used one but when we were first starting out modding
the standard's ( there are many threads if you do a search ) I ended up with itelite panels .
I liked them better from all I had read on those .Learning how to position them will help you .
Lots preferred those but you can see here what I did .
hcashmore11
