iOSD Mini
Dear All,
I am using the iOSD Mini with FPV Hub with my Phantom 2 using Immersion RC 600mW. Transmit and RC800 receive
I found that my video is very blur and the Flight ✈ data is not showing on the screen.
May I ask is that I set something wrong?
The result on GoPro is fine
Yes, I think I am.
Is that I can check it through the phantom 2 for mac software.
If yes, I think I did check to see if I m on latest firmware.
the iOSD Mini has it's own assistant software. You'll need to connect to it directly
If when flying you don't see any data you have to plug in in and update it to the latest firmware. Also it helps if you go into the go pro and turn off the display. That way you only see the display from the iosd
You need to upgrade the firmware.
Plug you cable directly into the IOSD mini and use the IOSD mini program. Run the update and you will be fine.
Thank you very much for all the reply.
I will test it and reply later tonight.
Running wedding event right now :)
Mav456 said:
Anyone know if you can change the setting from meters to feet and speed from ms to mph in the iosd?
Not available (yet)
The Flight ✈ data is showing on my FPV Monitor, thank you very much for the help.
I have another question, my image is very blur. Is there anyway for me to improve it?
I just ordered the osd and is there a mac version of the software. If so could you post a link please.
I dont think there is...I had to use Parallels running Win8 to update mine...
Johnboy94
