Daninho said:thanks, it seems that i have to calibrate the voltage in the Naza, its strange that the voltage differs so much but which device should i trust now, the cheap lipo checker from amazon oder the Naza itself? I think i will test the voltage with my battery charger, i hope the charger will not differ as well, then i would have 3 different results.
To the blinking problem, you can update the mini iOSD FW i guess, the software is the same as the bigger iOSD but dont know if that helps. For me its not an issue that the voltage is not blinking when low, i always have an eye on the voltage when flying FPV, maybe you also need the newest naza FW but over all its not a big issue when the voltage not blinks as long as it shows the correct voltage all the time.
Yes, I updated the firmware on the iOSDmini. It made no difference. Also, my home point "diamond" was very inaccurate which is not normal.
On RCG, there is more than one report of the unit failing completely after it was working, and it has the blinking led. So, hopefully the blink and the failure are not related.
