Can I install an IOSd mini on my phantom?
Discussion in 'General Discussion' started by windrockwater, Oct 17, 2014.
  1. windrockwater
    I have the original phantom. Its the one that came with the controller that has the sticks that return to center (is that 1.1 or 1.2 - not sure?). I have since installed a Zenmuse H3-2d and a Naza M V2 power adapter. I am using a Hero Black 3+ and also have the fatshark video transmitter mounted on the phantom. I receive video on both a set of dominator goggles and a small LCD monitor with a receiver (at the same time).
    So the only gizmo missing is the iOsd mini. Can I purchase one and open up the phantom and install it? Will i need to solder some more connections to get it installed or is it plug-n-pray? I cant remember but i guess i soldered the PMU to the board or maybe i used the power connector (i really cant remember and do not want to open the phantom again until i am ready to install the iosD since things are kinda crammed in there).
    Also, does the iosd info show on recorded video or is it only shown on the video receivers (the LCD and the goggles)?
    Thanks for any tips!
  2. Suwaneeguy
    Use the FPV hub. Plug all the wires into it.
    You'll find a tiny little switch in one corner, just make sure it is flipped over to the iosd side or you will get no info.
  3. ElGuano
    I don't think the FPV hub will ensure a solder/crimp free solution if you are not on an AVL-58 transmitter.
    But you can add the iOSD mini. The CANBus plugs into the PMU-v2, the h3-2d GCU plugs into the iosd, and you will need to splice the signal from the gcu to the fatshark to put the iOsd between the two. It should be pretty straightforward but the wire work needs to be done.
Similar Threads - install IOSd mini Forum Date
Help with AVL58 TX, IOSD mini and Hero 4 install WITHOUT gimbal. Phantom 2 Discussion Feb 1, 2016
P2, Immersion RC 600mw, IOSDmini Install Location (Whats Best?) Phantom 2 Discussion Apr 18, 2015
Two phantom 2's. 3 controllers, 4 batteries, MiniOSD installed on both, Tarot Gimbal, Mobius mount w Classifieds Apr 9, 2015
Anyone install the DJI mini IOSD on their FC40? Phantom FC40 Discussion Feb 16, 2015
iOSD mini install with kumbacam advanced fpv kit FPV (First Person View) Aug 16, 2014
