Interesting ARGtek car mounted antenna
If you determine what kind of connector your controller has already, search Amazon for a adapter. You will lose .25db with a adapter, but it'll still work.
Your cables appear to be: QMA type I am unfamiliar with them. However this might work if you can determine if your QMA cable ouput end is male or female
Amazon.com: 6 inch RG174 RP-SMA FEMALE ANGLE to QMA MALE ANGLE Pigtail Jumper RF coaxial cable 50ohm High Quality Quick USA Shipping: Electronics
Yep that does look like it will convert it over, ok I'll have to do a little investigating and see if this is gonna perform better then the range extender I have, I like the fact that they go one the roof, can you link results? And give your personal feedback
Ok, looking on the command site this is what you'd need to convert QMA to SMA
COMMAND Case Ground Station
(Expensive)
If your referring to this one then I already have this, that's why I asked you to look here as I have some of these cables
Yes, that will adapt/convert QMA to SMA.
MS60
