Increase the thickness of the iPad clip
Hello, I have a Phantom 4 that I use with a mini iPad. My iPad is in an Otterbox box case but unfortunately the clip of the holder does not hold it firmly because my case is too thick (around 15 mm or 5/8 "), so I am looking for an accessory that allows me to increase the thickness of the support. I have seen that there are many accessories to increase the height of the support but it does not seem to solve my problem.
Thank you for your help !
I had the same problem with my full size iPad. It would not come close to fitting with the case on. I had previously ordered an extender attachment from AMAZON.com so I could use the larger iPad. I had to give up on using it with the case on so I just removed the case and it fit perfectly.
Jim
WA5TEF
If you happen to locate an accessory to fix this problem. Please update.. I have the exact same problem.. For right now I use velcro as a temporary fix
hcashmore11
