Immersionrc 600mW and DJI Hub play together?
Some soldering will be required but not as much as without the HUB. I would imagine someone will come up with custom cables for specific vTx's.
adanac said:
http://www.firstpersonview.com/cables/phantom-2-iosd-mini-transmitter
with this Plug and Play Cable the IRC 600mW Transmitter interfaces with the iOSD Mini instead of plugging into the VTX port of the FPV Hub? I am considering upgrading from the AVL58 to the IRC 600mW and was looking for a simple no-soldering solution.
That cable would basically replace your FPV hub, if that's what you're using now. Your gimbal cable would connect straight to the Phantom's mainboard instead, and that cable adanac linked would go from the mainboard to the iOSD mini and then on to the IRC Tx, feeding it video and power as well.
would this cable suit me better seeing that i'm using the FPV Hub?
http://www.dpcav.com/xcart/Video-Cable- ... Shark.html
adanac said:
I'd like to install the immersionrc 600mW vtx and the iosd mini. Will the DJI fpv hub allow it all to come together without soldering?
If your going to use your video Tx Immersion along with the DJI iOSD then you need this cable http://www.dpcav.com/xcart/Video-Ca...SD-Mini-and-Zenmuse-ImmersionRC-FatShark.html I'm using this exact plug and play cable from DPC AV with my Immersion 600 and the DJI iOSD and without the DJI FPV hub. It plugs directly into the P2 Central Circuit Board, iOSD and the Immersion.
You could use that with the hub and your Tx, yes...it just won't be nearly as neat and tidy in the end as using the cable adanac suggested.
The cable Alex linked above is just another version of the same one from firstpersonview.com.
intertronixlabel
