- Joined
- Nov 30, 2020
- Messages
- 25
- Reaction score
- 23
- Age
- 76
Thanks, WV........I appreciate the info?????RTH works great. You also see your drone while flying, so there is no problem. I had a crazy phone that would cut out on me. I just kept flying and brought it home early.
Your iPad doesn't control the drone .. the controller does.is it possible to eyeball the drone back or hit RTH button and be OK? TIA, GUYS
While you’re flying turn on “Do Not Disturb” on iPhone and/or iPad. It’s the crescent ? moon icon in the Control Panel.is it possible to eyeball the drone back or hit RTH button and be OK? TIA, GUYS
To be fair, when calls come in on the latest iOS, it only puts a notification at the top of the screen instead of taking over the entire screen like it used to, but I agree - DND on any drone-related device.While you’re flying turn on “Do Not Disturb” on iPhone and/or iPad. It’s the crescent ? moon icon in the Control Panel.
Thank you for that info ?????Your iPad doesn't control the drone .. the controller does.
The iPad just gives you the view from the camera and telemetry.
Easy to check for yourself by hovering your drone close where you can see it ... say 20 feet away and pull the cable from the iPad.
The drone will continue hovering.
Then use the controller a bit and fly around.
Plug the cable back in and it's back to normal.
Depends on the app.Your iPad doesn't control the drone .. the controller does.
If you want to be pedantic and talk about specialised apps used for programmed automomous missions, It's still the controller that controls the drone.Depends on the app.
If you want to be double pedantic, if the iPad is controlling the controller, and the controller is controlling the drone, is the iPad not indirectly controlling the drone?If you want to be pedantic and talk about specialised apps used for programmed automomous missions, It's still the controller that controls the drone.
True. But that's not using the iPad AS the controller. In that situation, the app can completely crash and it will have no effect on the mission. I actually experienced this just 2 days ago on a job. The app crashed, but I let the drone finish its mission umimpeded.You can use a mapping app to load a programmed flight into the drone's internal memory.
And ATTI mode (AKA: The panic button) takes the drone out of ANY intelligent flight mode, INCLUDING RTH. So while your statement is technically true, it goes without saying and proves nothing regarding what the iPad is or isn't doing.But the controller still is connected to the app and at any time the flyer can resume control by flicking the flight mode switch to atti and back.
Really?If you want to be double pedantic, if the iPad is controlling the controller, and the controller is controlling the drone, is the iPad not indirectly controlling the drone?
Nope. Talking in circles here. It was already established that IF the APP is controlling the drone, unplugging the iPad or crashing the app will stop the mission dead in its tracks. I use these apps every week. Some apps upload waypoints to the FC so the drone can fly autonomously sans iPad, and some apps control the drone in real-time, in which case the iPad must stay connected and the app must stay running. They are two completely different situations. Other apps do BOTH.Really?
Since you can unplug your iPad and continue flying as if nothing happened it's hard to see what you are getting at.
