Hub Unplugged - Ok to Store Batteries on Hub?
I'm fully up to speed on using the hub and removing batteries immediately after charging. But I can't find any info on the possibility of placing the batteries on the hub during travel, or even on a multiple day trip.
I happen to have a case that holds the hub with three batteries mounted perfectly. But am definitely not going to try this until I get some feedback from others.
Thanks for your help!
I would not think the batteries would drain in the hub but I would not keep them in the hub as a storage rack especially if you travel as the vibrations could cause premature wear on the battery contacts. I allways place my batteries in storage mode back in my case where they are protected and padded from vibrations or impacts.
I do leave three of my batteries in the charging hub (after being fully charged) with no apparent problems over the last year or so.
Just before heading out, I turn it on to see if all three are still at 100% or if they've started to head towards the 50% range while in storage.
AD
