how to unscrew shell of P2V w/ one of the screws f'd up?
Basically I'm trying to unscrew the shell and one of the screw-tops is ****** up. I'm not quite sure how to go on about this. I don't even think I applied that much pressure on un-tightening the screw but I guess it's a little bit sensitive. What should I do here? :oops:
Had the same thing happen to me. I took a drill with a small bit and carefully drilled the head of the screw off. It wont take much pressure to get the job done.
Quadzilla. said:
Left-handed drill bit or you can also jam a similarly sized torx head into the ruined hex head and remove it.
Okie sounds good! I will do that in few moments :ugeek: thanks fellas, will let you know what happens!
robvalduga
