How to FPV my Phantom 2 ZENMUSE H3-2D GoPro Hero 3+ Black
Re: How to FPV my Phantom 2 ZENMUSE H3-2D GoPro Hero 3+ Blac
Use velcro tape or dual-lock tape so you can remove and replace it easily.
You can't control the shutter when flying. Do not use the wifi connection when flying - it will interfere with your tx /rx signal and you could lose your phantom ( there are loads of postings about this).
You can set time-lapse to take a photo at a set interval, than just select the photos that you need. Some people shoot high res video and take a snapshot of the frames they need. I haven't used either method so can't give specific details but these pointers will give you an idea of areas to investigate.
I just set mine to take pics e very 5 seconds if you have it on pics only you can see on the fpv screen when it takes a pic so easy to time and frame shots. You can also set it to video and pics at the same time but you can't tell when its taking a pic on the fpv then
Sent from my S4
JimM said:
I found this GoPro controller. It Won't work with the stock phantom receiver. You would have to replace the onboard receiver and stock tx with a matching tx/rx.
http://www.gentles.ltd.uk/gentwire/hero.htm
Just beware of this part:
Oops.. I didn't pick up on that. No good in this case then. Thanks for pointing it out.
Note to myself.. Read the full article [properly] in future....
filmowaniezpowietrza said:
Hello
I need to FPV my Phantom and here is what I want to buy:
Monitor:
http://www.ebay.co.uk/itm/Feelworld-7-I ... 2a222b6d06
Transmitter:
http://www.ebay.co.uk/itm/DJI-5-8G-8-Ch ... 4610585129
But I wonder how to connect that transmitter to my drone. Glue it?
Also, how I will be able to control my GoPro? Lets sa I want to shoot few photos for a panorama.
I recommend you check out Heli-Pal. Here's the one that I got:
http://www.helipal.com/storm-all-in-one-fpv-combo-deluxe.html It's the perfect plug and play.....if you ask me.
Anytime Express
