How to decrease video transmission bitrate?
Hi All,
I searched but could't find it in the Go app. I looked in the HD menu but it's not there even when the Phantom is powered on and connected.
Thank you kindly.
Thank you for your reply. Please excuse me if this sounds stupid cos i'm a first timer :)
How do I switch to custom mode?
Thank you kindly.
Go into the setup menu and choose the HD option. You'll see buttons for Auto and Custom. Just tap the custom button and the Image Transmission Quality slider will show up. Note that in Custom mode, you need to select a channel. Once you select it, you will be locked to that channel.
Thank you so much for your reply. I will try it.
Anywhere I can read up further on the matter? Links or videos perhaps?
Thank you.
I checked it just now on my Go app, with the drone connected and this is what I see: No custom setting. Does it have anything to do with the country it is set up to? If so, where do I change it?
Any info is appreciated :)
Hmm.. My screen is different. I have the option to select auto or custom. I have no idea why you can't. Perhaps it's country related. I'm in Canada for what it's worth.
This is iOS DJI-Go 2.8.4 running on my iPad Pro 9.7
Thanks. I guess it must be country related then... Is it possible to change the country?
I'm on Android fwiw.
You might want change the Country of your droid to...................
US !
Of course restart Go App when done
Reactions: The-CROW
Nwbailey
