- Joined
- Mar 20, 2016
- Messages
- 440
- Reaction score
- 163
- Age
- 37
I think this matter deserves a sticky thread. There are some questions I'd like to iron out, I am sure a couple of others have questions as well. Let's make a kind of FAQ.
There are two modes for focusing, Auto and Manual. My questions:
In Auto mode:
* If I choose to focus on an object 10 meters away and then approach it until it's only 5 meters away. It is kept in the focus point box the entire time. Will I still have focus on it?
* If the answer is Yes: I take focus on the same object. It is 10 meters away. I pan, and the object leaves the green auto focus box on screen. In comes a corner of a house, which is only 2 meters away. It enters the focus box. Will the camera switch focus automatically?
* If the answer is Yes: Will it find focus immediately or will it perform a whole "focus range test" to find appropiate focus and then apply correct focus? It matters because the auto focus procedure is a disaster in an important shot.
Manual mode:
* The manual mode has a "wheel". What is the point of the focus box? Is it only to help you see appropiately when you use the wheel?
* The wheel is not logic to me. On the upper side there is the macro symbol. On the lower, infinity symbol. That is logic. What is not is, if I turn the wheel by pointing my finger closer to the macro symbol, the wheel turns towards the macro symbol. This would imply I set focus at minimum distance. However, the position of the wheel is now in the maximum end: the end closest to the infinity symbol. Have I just set focus minimum distance or maximum distance?
I assume the focus point in manual mode stays the same at all times, regardless of what enters the box.
If one wants to apply infinity mode as on the P4 and older models, you enter Manual mode and turn the wheel to the direction that soon will be answered as the infinity direction.
In Auto mode:
Manual mode:
