Hello all, today I was flying my p1 and it went out of sight but luckily when I lowered its altitude it reappeared and I was able to make a safe landing. This makes me pose the question: how high do you fly without an fpv system?
I can't get past 860ft (262m) no matter how hard I try :-(. No limits set, open ground in the middle of farmland. P2V+V3 controller set to FCC
I've set the "Max Radius" limit to 400 Meters in the NAZA assistant. That way I won't be searching for days if something goes wrong.![]()
IflyinWY, What if the "something" that goes wrong is NAZA Max Radius limiter?
SnoozeDoggyDog, I had the same issue. Definitely not the most technical answer, but I think I had a faulty wifi module that was putting out 25% which translates to about 275m.
Sorry I didn't quite explain myself. I have limits set but they are way beyond what I can reach. Height limit is 300m and horizontal to 400mReally?
You say "No limits set", does that mean in the NAZA assistant software, at the "Advanced" tab, then the "Limits" tab?
You might want to go look there at your "Max Height" and "Max Radius" numbers. If there is nothing there, maybe you should put something.
Something isn't right. What happens when you get to 860 feet? Does it look like it's run into a soft wall, or does it execute RTH?
Yes, when I hit my maximum distances the Phantom hits a soft wall, no RTH. I thought the Phantom was automatically limited to 500ft vertical in the UK so didn't give it anymore thought. But horizontal I can't breach 860ft
farthest ive had mine out was around 1440 feet
