How do you slow down the pitch speed on zenmuse with p2?
I tinkered with the settings but couldnt get it to slow down. The speed of the pitch is so unusable for video as its not smooth. I had a tarot before this and i could tune it so well to get smooth pitching.
That isn't an option right now with the Zenmuse. Those settings in the software have no affect.
With luck maybe they will become active in a future firmware update.
I am considering installing a multi-turn pot to have smoother control of the gimbal tilt.
I feel like reverting back to tarot. Does the gain settings still work to adjust the tilt speed with phantom 2?
If the gain settings are on the IMU of the gimbal itself it should still work the same as you are expecting.
This issue with the P2/Zenmuse is that the IMU for the gimbal is now inside the NAZA. The current firmware doesn't allow those values to be changed.
ah man then im all out of luck. i had to slow down the tilt using the Naza IMU on the phantom v1 with the tarot. Why arent they allowing us to modify the gimbal settings??
