How do you downgrade the firmware?
Can anyone give me assistance how to downgrade the firmware, I am struggling to get further than 70meters away. I have read downgrading the firmware may help but have no idea how to. I’m using an iPhone XR with my Dji phantom 3 standard
Reactions: jeffchicago
Make sure that beginner mode and distance limit is turned off. That may be the problem you are having with only able to go 70m away.
To do so, enter the MC settings by going to the top right corner of your screen and then the little AC tab at the top. There you will find beginner mode and distance limit. Make sure that the green switches are turned off.
If that does not solve the problem, you can try downgrading using the following method...
Turn on the drone and controller and connect to the app. In the app, tap and hold the 3 line menu button (like shown below) until a firmware screen appears. Select the firmware you would like to downgrade to and tap "Download Firmware". Wait for it to download and install and restart the everything.
hcashmore11
