denodan said:Still using the same AA batteries in my TX. How do you know when they are going flat?
When the voltage is lower than 4V, the transmitter will alarm with sound of “BB............”, please change the batteries
telecaster said:Dont do as I did, when turning on the TX saw rapid red flashes from the LED and changed the batteries
the red flashing means linking between TX and RX, it should change to a stable red light after a little while.
telecaster said:from the Phantom manual:
I wonder how much TX range is affected when you get the low battery warning? Testing indoors will not reveal any deficiencies in range.jumanoc said:telecaster said:from the Phantom manual:
I tested indoor without props, simulating flying after BEEP ... BEEP on battery low TX.
Bored after 38 minutes and 3 phantom battery change...TX still working with "low batteries"... So after TX battery beep alert, you can use it at least 20 more minutes ( at your own risk :shock: ). DJI wrote: don't worry... After beep alert your TX keep working, just replace your batteries as soon as possible.
Well Sir, I never said they did, I just said they were doing the linking sing and dance number.Gizmo3000 said:the Tx and Rx do no communicate back and forth. the Tx transmits, and the Rx receives.
the Tx has no idea if it's connected to the Rx
