Thats great!! So we know the panel is good!...so maybe beaus cables are bad?
sent from my POS Samsung Galaxy
I seen some of those on ebay for a really good price...it's very tempting to get one just to try it! who knows, might work really good for the p3s or p2vYes, 9000 ft with the 17db vs 17000 ft with the 19 db is not a little thing.
Looking forward to the next test.
Meanwhile I fell upon this, this morning.
L-Com HG5827EG 5.8 GHz 27 dBi Die Cast Aluminum Reflector Grid Antenna
Only 9 degree and 6 degree beamwidth, but 26 db! I'm thinking it might work for a long straight run...
Hey DB, it was starting to loose bars at 3000ft correct? That's where I could get no further, even fighting it left me disconnected. It started to loose bars at around 1500ft, then I'd have to raise altitude to get another 1000 out of it. I give you props for getting out in this terrible heat, and fighting that wind as well! Honestly, I like having the 3 foot cables, I can step back without having any weight on the controller. Is there a better cable type than the RG-58?I didn't have any luck using my longer cables the three-foot ones that came with it, I think he did use those maybe that's his downfall. That being said I still expected more out of that 17 dB panel. But it seems like that 9000 foot area was a roadblock for both of them, mine was just able to fight through it. I'll wait for a calmer day. And try them both boosted with his amp
Wow, 45,000!!! Great work man, I knew you'd be the guy to see what these things can do. Will did a good job making these things both durable and perform excellent. Is you're gimbal okay?Just did 45000 w/ the p3S and BeauS's amp and antenna also had the craziest flight of my life! Barely got my bird back!! Fill you in laterView attachment 60915
**** DB thats crazy...i woulda freaked out bad!! It sux flytrex doesn't have smething for the standard
Okay DB, how far can you go on 10% landing? Never tried it!
