Hi all,
Here's my attempt at an internal lithium battery, charge port, indicator LEDs and charged/charging LEDs.
The two LEDs above the neck strap point are top charged (green) and bottom charging (red). I attached a prototype PCB from a portable hand held 'appliance' from where i work, hooked into that charging circuit, wired in all the LEDs to pads that were for surface mount LEDs, and also have a charge jack on the rear. All tested and working fine. The power is regulated once it enters the PCB so the 7.4V provided by the li-ion battery is ok, regulated to 3.3V i think (all the points i probed were 3.3V anyway). I needed to solder my PCB switch to the Phantom TX power switch, my PCB switch switches the positive but the Phantom on/off switch switches the negative so i couldn't turn on my PCB using the Phantom on/off switch. So i found a positive voltage that was switched on and off via the Phantom switching on and off, then wired my switch to that one point, which was off a large Capacitor on the under side of the Phantom TX PCB.
Anyway just thought i'd show you all my efforts
Regards
Regards
