Hi and help please
Tucson, AZ
What a way to begin....
I've been lurking here for several weeks and have had my Phantom for almost as long. I've found it easy to fly and operate until this morning.
I had installed the prop guards (training wheels) for the first couple flights in order to save on any mishaps; everthing was good. I decided to remove them a couple days ago and haven't had a chance to fly until this morning. I go through the normal power up only to have all four props studdering with little power. No additional power from the controller. I chacked everything and the only thing thats changed it the screws being put back in place after removing the guards. Too tight? I went through each motor tweaking the 2-screws and got first 1- then 2 working as they should (both clockwise) the remaining props are still studdering or not turning at all with no light on under the arm.
What am I missing?
Thanks in advance for any information. I bought this from B&H and they CS is less than good so I turned here for help.
I had installed the prop guards (training wheels) for the first couple flights in order to save on any mishaps; everything was good. I decided to remove them a couple days ago and haven't had a chance to fly until this morning. I go through the normal power up only to have all four props studdering with little power. No additional power from the controller. I chacked everything and the only thing thats changed it the screws being put back in place after removing the guards. Too tight? I went through each motor tweaking the 2-screws and got first 1- then 2 working as they should (both clockwise) the remaining props are still studdering or not turning at all with no light on under the arm.
What am I missing?
I read somewhere, no actual first hand knowledge that the screws that hold the guards on are longer than without the guards. Could that be a issue?
E
Iron Creek said:
Crap!
I could have sworn there wasn't any screws included w/the guards. Oh well looks like I need to replace 2-motors.
Thanks
Don
Hey, I would have probably done the same thing.
Not sure what the outcome of the other post was.
Feel your pain brother.
E
Sent from my iPhone using Tapatalk - now Free
Iron Creek said:
Just order 4-new motors and a screw kit. Should be back in the air in a couple days (fingers crossed)
Don
Climb back on that horse and ride!
E
edunwody said:
Don
E
No worries on that. I've cracked the case and unsoldered the first of the 4. Should have the replacements Fri along with a screw kit. Looking at Sat to be back in the air. Need this working as its going to Jackson Hole WY in a week.
Don
Thought I'd offer an update...
Thru my own stupidly I reused the longer screws from the guards after removing them causing the motors to quit. I went to UAV Direct and ordered OEM replacements arrived yesterday and immediately went about installing them. The first 2-went on with little to no problems, the 3rd caused me some slight problems which included melting a small portion of the arm. The 4th was a complete disaster; not only did I melt a small area of the arm, I also got the very last connector so hot that it separated from the ESC. I powered up just to see what the damage actually was and found I had 2-motors at full speed, one stuttering and one not moving at all (the broken ESC).
I guess I could replace the ESC however I feel I met my match. I remember Dirty Harry saying "a man has to know his limitations". So on to Plan B - I have a new one coming early next week which is just in time for me leaving on a 4 week photo shoot. Plan C might be selling the controller and charger while Plan D is to sell the older bird for parts.
Despite all this I really enjoy flying and can see how it could be incorporated into our work.
Don
Don
If it were me, I'd send her to a Phantom shop and let them repair.
That's just me.
E
That's just me.
E
I would however i need/want this in Jackson Hole and don't have the time to wait. The good news is that I sold the unit to UVA Direct my new dealer and have a replacement coming early next week. It maight not be the most cost effective way however if I can get usabe footage on this next trip it will more than pay for itself.
Thanks to all
Don
DonT
