Help Identify used phantom 4
I purchased a used Phantom 4 at an auction its missing the remote and battery charger .
how can I identify the exact model so I can purchase the correct Remote/charger ??
Thanks for your help in advance !!
Look for the Model Number inside the battery compartment.
Any Phantom 4 charger will work but you will need the proper remote.
This will tell you(most times)what it is and when it was built.
Reactions: KachemakDiver
D serial worked great ! Thanks to all for the help I have a remotes ordered that should work
Something to consider if you truly have a p4. Some may complain that the range on the p4 is not what they would like. Another controller that has a bit more power and works with the p4 is the inspire1 GL658C.
more reading for you!
shimuafeni fredrik
