Hard to Fly "Straight" After Crash P3A
I crashed my phantom a few weeks back and did a DIY repair on it. Now it is a bit hard to fly it straight.
Specifically, when flying slowly, if I push the right stick forward (or backward) it tends to want to drift to the left when going forward. Sometimes when I push the right stick to the side, it wants to back up a bit.
I also notice that if I am using the left stick to change altitude it tends to want to rotate a bit.
Even when hovering it tends to be a little less stable.
I included this video although I don't know how helpful it is since you can't see the stick inputs.
I understand this could be down to pilot error or wind. So are there things I can do (calibrate IMU??? Calibrate compass???) that might help?
Always calibrate the imu on a LEVEL surface after a crash or bump. It sounds like an imu problem for sure, but it could also be bad props or something else could have been damaged in the crash as well...
Reactions: Just Mark
