Happening to anyone else...drifting?
I am flying in Phantom mode, but during the last few flights my Vision + seems to be flying in Naza Attl...I get 6-7 satellites to lock, calibrate compass before flight. After takeoff it does not stay in one position like the first 2 dozen flights. It will either do a latge 15-20 ft diameter circle or when flying left or right just keep drifting it that direction... this will last for about 3 minutes an then be back to lock on . The app and the leds so blinking green or 7 sats...I have not checked calibration yet...I am using 3.0 and 1.0.39 for the app.
Sometimes, even though you have a fix on six satellites, you can have bad GPS geometry. i.e. you are locked on to six satellites that are in a straight line to each other. Though you are locked on six birds, the geometry offers a less precise position than if the satellites are spread out across the sky.
its not possible for you to lock onto 6 gps satellites that are in the same plane. There are only 4 satellites per plane/ Those 6 he locked on to are definitely spread out. what he is describing, to me, sounds like a compass calibration issue.
DBSAM said:
I compass calibrate before each flight.
make sure you calibrate in an open area and away from metallic items. i had this same issue at one time and once i calibrated in an open area, the drifting went away.
I took a magnetized screwdriver to my compass, I had drifting, the software said it didn't need calibration, but I did it anyway. The drifting went away.
After you magnetized the compass did the app indicate to recalibrate the compass?
I think the manual recommends not doing this. Some flyaways have been attributed to compass calibration too frequently. I understand you only need to calibrate if you're going to another part of the world, not from one nearby location to another nearby location. I understand the concern is if you do the calibration too often, eventually you will do it wrong or do it in a bad location and have a poor compass setting. YMMV
It did NOT indicate any need to recalibrate the compass. According to the software everything was ducky...and it lied! A forced calibration seemed to fix the problem, but it seemed she never really flew the same after, so I bought a new compass.
Now it may be that I'm just ****, and for some reason I just "believe" there was something wrong with it, but for 25 bucks my OCD gets satisfied, and I'm good again.
I hear you;)
Was yours drifting and circling the whole flight or at the beginning of flights like mine?
[/quote]
I hear you;)
Was yours drifting and circling the whole flight or at the beginning of flights like mine?[/quote]
The whole flight.
DSays
