Had a bad auto take off tonight
JRH
End in evergreen now all I get is a esc alert where is the best place to send for repairs (no dji care)
I never go for auto take off and do it manually as that gives me more controls and confidence. I quickly take it up to 10-15 feet.
Depending on where you are located DJI repairs can be a good option. It seems likely you will need a new main board to fix the esc issue.
I STRONGLY suggest before you send your P3 off - you read my thread HERE, of the same problem and a solution that works.
Sending it off to DJI is not the only solution - yet. Good luck.
Steve I tried no results. It leaves tomorrow. Any idea how long of turn around
I had one situation that I had to send in to DJI. The right joystick broke away from the R/C and dropped down into the housing. DJI sent me a call tag and turned it around in about two weeks. It went to California. They simply replaced the R/C. Simple pairing it to the P3 and I was off again.
robvalduga
