H3-2D Motor housing Disassembly?
after a crash one motor of the gimbal doesn't work more than 2 second after power on.
there is a grinding noise, i suspect some dirt got inside.
Anyone has disassembled the motors? Looks like the metal cage around the winding hard to come apart I plan for a cleanup (with alcohol?)
CityZen said:
Try compressed air.
sure, this would have been last attempt before disassembly, will even try vacuum cleaner (in order to prevent dirt being push/stuck deeper into the motor).
Thanks anyway.
DeweyAXD said:
Youtube is your friend if you do decide to take the plunge:
Thanks, unfortunately looks like it stops at the whole motor & housing.
Anyway I disassembled only the ribbon plastic guard and using vacuum cleaner & compressed air I succesfully removed the dirt.
The gimbal now works.
Reactions: SFXD
rockymountaincaptures
