Ground Station Questions
Hi
I've been using the ground station in the Vision app today. I set waypoints and hit go and the quad started the mission. The 4 waypoints were on the map with lines between them showing the intended course. I lost wifi connection and all the lines and waypoints disappeared from the map. Is this normal?
Secondly, when I regained wifi signal the waypoints seemed to appear at different points on the map and with different numbers. The lines between them weren't as I had entered them either. By the end of the mission my waypoint 1 had become waypoint 7 on the map (even though the whole mission only had 4 waypoints).
All that said the bird did complete the mission as directed but it was a bit scary when the ground station map seemed to suggest it was going to fly in all sorts of directions when ever wifi connection returned.
