Ground Station Pro Max # of waypoints
Has anyone run across the problem of too many waypoints while doing a 3d-map in Ground Station Pro? Apparently it only supports a maximum of 100 waypoints, anybody know to increase this number?
I wonder if there is something internal to the system that limits it. Litchi limits too, 99 WP there.
Yeah autopilot doesn't have that limit but then again autopilot doesn't push the entire mission up into the flight controller either unless you specifically make it a LCMC mission. I use DroneDeploy and Pix4D a lot and I've never run across this issue that I can remember so I probably need to double check to see how those apps handle it.
No solution except to switch fixed distance or fixed time photography. Then only the drone changes of direction are recorded as waypoints.
Reactions: Hounddog
Usachman
