Has anyone run across the problem of too many waypoints while doing a 3d-map in Ground Station Pro? Apparently it only supports a maximum of 100 waypoints, anybody know to increase this number?
Yeah autopilot doesn't have that limit but then again autopilot doesn't push the entire mission up into the flight controller either unless you specifically make it a LCMC mission. I use DroneDeploy and Pix4D a lot and I've never run across this issue that I can remember so I probably need to double check to see how those apps handle it.
