thongbong said:The GPS itself is about 100 but you get 3 months free after that and you can cancel anytime and resume anytime. If you take apart the pet collar and extract the GPS and battery itself, its only the size of 4 quarters stacked on top of eachother.
lgeist said:thongbong said:The GPS itself is about 100 but you get 3 months free after that and you can cancel anytime and resume anytime. If you take apart the pet collar and extract the GPS and battery itself, its only the size of 4 quarters stacked on top of eachother.
Once you extract the GPS and the battery from the collar, are you still able to charge it with the included charging dock?
thongbong said:You'll have to do a little soldering, five points of contact for the charging port and 2 points of contact for the antenna. I soldered the contacts to a female 6s balancing cable and I soldered the male 6s balancing cable to the charger. Granted you'll need to have some experience soldering but well worth it to get it done or find someone to do it for you. The battery itself is only a 3.7v and if you take that off, the GPS unit is only the size of a quarter!
Do you intend to use a DC/DC converter or power it off it's own battery? Even though it's more weight and more cumbersome, a separate battery that can't come loose like the main one would be preferable.
Also, what will you use for an antenna? Weight of the extracted unit?
Mosleyh said:If I was looking in the $100+ range, I'd seriously consider this one:
http://www.drone-mods.com/Drone-Mods-UA ... -DM005.htm
