- Joined
- Apr 15, 2014
- Messages
- 14
- Reaction score
- 0
Took the plunge and purchased a Trax this morning. Still waiting on my Vision+ to arrive but at least I have the insurance policy on order.
Got an email back this morning.Farside said:I emailed Trax asking if Amazon will get them in May as well.. we'll see.
I'm sure it will work, but you will need a sim card of course as well... let us know what option sim you got (plan and cost) and how well it works for you...Mori55 said:I just ordered the global tracker 102. 33.00 amazon prime, will have tomorrow. If works great if not , it's only 33.00.
See #5 in first message of this thread: viewtopic.php?f=27&t=13834Mori55 said:Ok , going to see what tmobile has. AT&T wants a contract from what saw. I want to pay couple months in advance. Don't always fly in the winter.
That took me to a 'Bye Bye Vision' thread which i didn't see any message with a #9 in it...Aqeel200 said:
srandall25 said:That took me to a 'Bye Bye Vision' thread which i didn't see any message with a #9 in it...Aqeel200 said:
I assumed that you can still find the location of trackers (equipped with sleep mode) even hours after it fell to rest. Is this not true?jlarcher said:Some FYI for you,Trax will go into sleep mode to save battery after five minutes
I personally bought a http://www.pocketfinder.com/, It will go to sleep after 30 minutes of idle time, but that is plenty of time to lock in your location and get going. Check it out and let me know your thoughts......
Aqeel200 said:Seems accuracy has improved when placing the TK-102 near a window only blocked by the car porch compared to when the tracker is deep in the house.
How does this test relates to flyaway? Maybe not...different scenario altogether..
Sleep mode should not be an issue... The app stores and provides its last known location prior to sleep mode. If it is moved from that location, it wakes up and beacons its new location again. Sleep mode actually works to save battery life by not continuing to beacon the same location repeatedly...Farside said:I assumed that you can still find the location of trackers (equipped with sleep mode) even hours after it fell to rest. Is this not true?jlarcher said:Some FYI for you,Trax will go into sleep mode to save battery after five minutes
While not hibernating, are they not constantly updating a server somewhere their location so you can later retrieve this info?
That was my assumption.
Right on, thanks.srandall25 said:Sleep mode should not be an issue... The app stores and provides its last known location prior to sleep mode. If it is moved from that location, it wakes up and beacons its new location again. Sleep mode actually works to save battery life by not continuing to beacon the same location repeatedly...Farside said:I assumed that you can still find the location of trackers (equipped with sleep mode) even hours after it fell to rest. Is this not true?jlarcher said:Some FYI for you,Trax will go into sleep mode to save battery after five minutes
The fact that the battery lasts 2 months is the only plus to this one. You have to be within bluetooth rang of it to get its location. This means a long hard search for you that would be almost the same as tracking down the phantom itself by just getting back within wifi rang of it with your transmitter and mobile phone but with the added ability to search for it for two months before the battery dies.lilwheat said:I've had this one on pre-order for over a year:
https://www.sticknfind.com/Pages/?p=01B ... FACDD490A3
I'm thinking it's not happening. Their site says it will be shipping at the end of March, no year is given.
I was thinking samething , but I wonder if it would make it hard to squeeze the battery. Remember it can't touch the gimbal frame.ocphantom said:I mounted it between the legs on the left side, one zip tie around each leg with the gps tracker in the middle. Flew it today and the gps tracker has too much surface area for my liking and made it easy for the wind to push it along. Going to try velcro it flush against the phantom belly behind the camera
