GPS Mounting NAZA Setting change?
Hey guys. I have a P1 and am curious if I need to change the GPS mounting setting due to the fact that the ebay gimbal changes the center of gravity causing a large tilt takeoff. Would changing the GPS mounting setting accounting for the change in center of gravity cause the phantom to adjust and allow for a straight takeoff? Thanks.
I do not think the gps setting will correct for CG changes. The flight controller will do that but only so much. If you can not move something aft to compensate the cg change you can push the right stick forward to correct for proper takeoff while advancing the left stick, assuming you are in mode 2.
jeetbuzz360
