gimbal yaw question
When im flying the gimbal continues to yaw left even after its in a hover.
I have tried to calibrate the gimbal and the imu.
Any idea whats going on.
Both my advance and the pro is doing this
If both of your gimbals are doing the same, you have an evil eye there :)
Jokes apart, I think you are not doing calibration on perfectly leveled surface.
Ah i have done them both on the same table. Ill check the levelness of it. It needs to be exact i guess
Hello, I just calibrate the imu and the gimbal, use an app to check for magnetic fields and metal and other to check if it's perfectly level,
I use metal detector and bubble level on Android
Lol I will try and get a level spot and re calibrate both the I use and the gimbal. Thanks!
robvalduga
