Gimbal Problem
After replacing the yaw motor, the gimbal is only in this position!
yes, i did full calibration IMU and Auto Calibrate Gimbal.
Manually rotate the gimbal to the right until you feel a local or click. Then do a gimbal calibration.
Ted is the man!!! This issue has been addressed in previous posts by Ted and myself. I'm not sharp enough to give you the exact link, but the discussion is extensive and worth the read, if you can locate it. Be sure to SAVE THE OLD MOTOR. Ted and I are perfecting a way to replace the sensor/s, since the only motors available on eBay are NOT new and may have a damaged sensor. The motors are the same for the old and new version drum.
Cheers,
Jim
Reactions: Droneted
