Gimbal is not in center
After replays my YAW MOTOR my gimbal is not in center , I do lots of time gimbal calibrate and IMU calibrate but no improvement
Any solution ??
Have you checked yaw shaft alignment. There must be a set screw on the flat shaft of yaw motor.
I had the same problem with the yaw position post fix. Tried this and it seem to fix the problem
Place you P4 in this position and then do the gimbal calibration
Here is the link to the original DJI article
Camera face towards left instead of facing center.
i Do but not working , when i do in this position then its in center but when i do it in normal position its not in center
Yer I had that problem as well. Once you finished the calibration in this position power of the P4. Place it back on its feet and start. It should then be straight. Also check the rubber skirt is tucked in around the yaw motor.
Oh i also did an IMU calibration first, then restarted the AC and then did this gimbal calibration, then turned off AC in this position. Dont do a normal gimbal calibration after this one. On startup now it should be pointing straight...hope this is clear
juffe
