Gimbal control board with broken antenna sockets, repair or replace?
Hi,
I am new here, hope someone can give some advise,
I have a gimbal control board with broken antenna sockets, is it possible to have this repaired?
If not, if I buy a replacement control board does it just plug & play or is there some programming set up required?
The gimbal is also broken, Is it difficult to connect aftermarket gimbals?
I am trying to decide if it is worth trying to fix the drone or just buy another one already working?
I look forward to your replies,
Regards Dee
DJI gimbals are probably the only ones that will install in your controller.
You may find a used board somewhere, but may be just as well to by a used controller from someone here or eBay.
