Some cheaper drones come with a cheap stick that accepts the SD card on one end and the other plugs into the sub port. Don't use them! I've tried several and the video would stop have way through or I would get error messages. They just don't seem to be reliable. Spend a bit more like msinger's suggestion. If your computer has a standard card slot, but SD cards that include an adapter. All of those that I have used worked just fine in my MacBook.
After you download the micro sd card, open Photo's. You see the card listed. Click on that and select download. Once it's downloaded it will be in the media library of iMovie. Just drag it down to the project bar. Easy Peasy.
Greg: try YouTube there are heaps of videos there.
Two scenarios raised above:-
1. Transfer video to computer
2. Importing video to iMovie
Unsure which one you want but if 2. Then when you create a project you will get the option to load media. What I usually do is import the video to the desktop and go from there.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
