I have set the timers to remind me to bring the UAV back home.
Both timers start at the same time. The first timer is set to 5 mins and beeps after 5 mins to warn me to start bringing the UAV back home. The second timer goes off 2 minutes later (after 7 minutes) to say if I have not landed then do so.
Timer Settings:
Go into the 3/3 menu and select Timer
Under TMR1 - T = 5.00, MODE = DN-STP, ON SW = SWA DOWN (Switch A then is your start and stop) RS SW = SWH DOWN (Switch H becomes the reset switch)
Under TMR2 - T = 7.00, MODE = DN-STP, ON SW = SWA DOWN (Switch F starts and stops this timer), RS SW = SWH DOWN (Switch H becomes the reset switch)
Gimbal Tilt Setting (with Zenmuse)
Go into the 3/3 menu and select AUX-CHAN and then change CH5 to VR
The rotary VR knob will then adjust your Gimbal up and down.
Slowing Down the Yaw:
How to slow the yaw down on the T8J so you get better videos as the camera pans slower.
I have set my T8J TX up to do this using switch B.
Go into the 1/3 menu and select D/R EXPO then go across to CH 4,
Change SW to SWB (or whatever switch you want), flick UP switch B, now set the left and right EXP to minus 85% and save.
When switch B is up the yaw is greatly slowed down for the first half of the stick movement.
To really slow the yaw down flick SWB on. Change the EXP both to minus 85% and change the D/RS both to 50%
Remember to turn SWB off when you come down as you cannot stop the motors with SWB on with these settings.
