Front lens scratched, is it a protective cover?
I just realized that there is ascratch on the lens of my p3P. Is the front glass of the P3P a protective cover or is it part of the optical lens?
Thanks.
Thanks.
It is a "protective cover" in the form of a UV filter. and can be replaced or another type of filter glass be substituted.
Reactions: dirkclod
Thank you for your fast reply. Big relief as I was fearing that I had to replace the camera.
If you haven't ordered any or not using ND filters, you might look into that. You will need ND filters for filming in sunny or bright conditions-- they would actually replace the UV filter you have on the stock Phantom. There are several options available. Check Phantomhelp.com
Reactions: dirkclod
It unscrews and in a pinch there's always these :)
Just messing with ya Krauth :)
Bob shot ya straight ;)
Reactions: J Dot and bobmyers
