FPV interference in Phantom 2 with zenmuse h3 3d
  • Thread starter Thread starter Deleted member 19326
  • Start date Start date
D
Guest
I recently bought the Phantom 2 and an fpv kit.
I have the SkyZone TX51W transmitter (http://www.hobbyking.com/hobbyking/stor ... Search=1wa)
and the SkyZone RC305 receiver (http://www.hobbyking.com/hobbyking/stor ... eiver.html)
with the immersion RC Fat Shark SpiroNet antennas.
Video transmission works perfectly when i connect the gopro directly to transmitter but when video passes through the zenmuse H3-3D (1.1v with USB Ribbon Cable) i have this kind of interference
https://dl.dropboxusercontent.com/u/938 ... erence.MOV
I have also noticed that the fpv range is unusually poor (30 meters) even though i have 1000mW transmitter with Fat Shark SpiroNet antenna!
Can anyone help me?
Thanks in advance
Side scrolling... hmm. Seems like a PAL versus NTSC thing, although when I had that issue it was vertical scrolling I think. Check to be sure everything is running with the same settings.
Gopro is in Pal! What else do i have to change? I 've also tried the NTSC selection and it is the same!
Did you try NTSC? looks like the wrong signal format coming through both monitor and GoPro need to be in the same standard, either PAL or NTSC
Starbase
