FPV for Phantom1
Sorry to hijack the thread.... last time, I promise lol.
So here's the road I'm thinking of going down:
Immersion 600mw 5.8 Tx
Immersion 5.8 Uno Rx (going single to start off with and to save $$)
Fat Shark Teleporter V3 goggles
FPVLR Antennae
Immersion RC Plug And Play Cable for GoPro
Any issues with that set up or anything missing? Not looking for a fancy bit of stuff, it's just for framing shots.
Many thanks!
That all sounds good to me.
I see in your sig you have Dinogy 2800 Lipos. How long is your flight time? I bought a couple more batteries from Readymade RC just so I can stay out longer, but I'm going getting about 9 minutes of flight time. with 4 batteries, I'm having enough fun, but wouldn't staying up longer.
I'm in love with that P1>P2 shell thread that Dewey and IO post in. I'm contemplating doing that conversion just to hold 2 batteries.... That is further down the road from now.
The Dinogy 2800's gave the best results out of the several brands of P1-sized batteries I tested. On a loaded Phantom (H3-3D/iOSD mini/FPV) they could get me to just a bit over 10 min in hover tests, so you might be able to milk just a bit more out of them than that with regular flying.
Unfortunately it doesn't look like the new Multistar 4000mAh 3S will quite fit in a P1 (based on published dimensions), otherwise that would be the no-brainer option to use. :(
ATOMSK said:
would that Multistar 4000mAh 3S fit into a P2 shell?
Probably. It definitely will width-wise, and the height will probably be tight but workable. The length however may require a deeper than usual battery cover.
I'd go with the 5200mAh in that scenario anyway though ;)
Thanks for the reply!
So far I'm liking the Dinogy batteries. If I fly with a heavy left thumb I get about 9 minutes. With typical flying (for me anyways) I can get 11:30. They are a tight squeeze in the P1 and I had to cut some holes in the battery door and belly to run the battery wires externally. No room in the belly for the battery and the wires lol.
jorge sanchez
