Re: Vision+ Wi-Fi Booster DOUBLE FPV Range
Regarding Wifi security, I believe my proposed solution earlier (a few pages back) is a much better approach in terms of the followings.
(1) Safety - Wouldn't brick the Wifi in case firmware upgrade in future.
(2) Performance - Deploy WPA/WPA2 between P2V+ aircraft and repeater in long range Wifi network is likely to reduce bandwidth, FPV range and reliability. My solution is to deploy WPA/WPA2 between repeater and FPV device (several inches apart) to secure the "entrance" only.
(3) Security - Eliminate 99.9% unauthorized access while there is no way to ensure 100% secured anyway.
(4) Easy implementation - Simple to implement and use, and users can easily change the password in the app. In fact, we plan to implement this in our stage-2 booster app.
That's correct. If you change root password, the booster app wouldn't work.urgno said:a little question:
I'm reading the posts by linuxkidd about encrypting the wifi and changing the root password
I guess that if I change the password of the fc200/repeater, then the booster pgm will not be able to login to them to change the parameters to boost the signal
I'm i wrong ?
thanks
