Flying below
Discussion in 'General Discussion' started by Builder, Feb 28, 2015.
  1. Builder
    UK DEVON
    Sorry if this is a silly question but can you fly the pv2+ below you? I would like to get some footage of a dam nearby, and start filming at the bottom of the dam going up with me on the top.also what sort of range would there be? Standard set up,no mods etc. many thanks as always.
  2. PTCX
    Australia
    Yes you can fly lower than where you launch from. I've done this many times.
    The range should be the same as in any other situation.The signal is still subject to being blocked by large steel or concrete structures etc.When your flying near a dam try to avoid putting such structures between you and the Phantom.
    If your using FPV,depending on how/where the antenna is mounted there is the possibility that the quad could shield the signal and make the picture break up a little.
  3. Hughie
    Leeds, United Kingdom
    Gravity has no effect on radio waves (unless your name is Einstein :) ).
  4. Larry L
    Copperas Cove, Texas
    Yes it should be no problem except depending on how low & surrounding structures ( Canyon walls, Buildings, etc ) you could Possibly drop below desired gps signal & have to fly in atti mode.
Similar Threads - Flying below Forum Date
Flying below altitude of takeoff point General Discussion Jul 16, 2017
flying below takeoff point (home) Phantom 2 Vision + Discussion Jan 29, 2017
Flying below 0 feet on RC Pro/Adv Discussion Apr 20, 2016
Flying below freezing Pro/Adv Discussion Apr 6, 2016
Any advice for flying below starting altitude Pro/Adv Discussion Feb 21, 2016
