After daddy buys you a new one take it up real high. Do the CSC straight overhead then try to catch it.
Common sense isn't very common.
The OP was flying a non-Vision. So he could know via a Flytrex Core (2) or telemetry displayed via iOSD on an FPV setup.tcope said:How would the OP know he was at 4400 feet unless there was some additional sensor on the drone? I'm pretty sure this information is fed via WiFi and I can't see that being extended to 4400 feet without a serious additional set up.
Meta4 said:Sounds like you need to revise some basic arithmetic.
The Phantom descends at 1/3 the speed it climbs.
Now you have learned that.
Any idiot should be able to work out that it isn't safe to use more than 20% of your battery going up because you are going to use 3x (60%) coming back down. This leaves a safety margin of 20%.
Safety might be a new concept to you. Perhaps one you should become familiar with.
ps .. flying 4400 feet up with a Phantom is plain STUPID.
Obviously stupider than you understand even now.
Yes, manual mode would have let you come down as fast as you want. Maintain some forward motion to keep from entering VRS then you can switch back to ATTI when you get 20-30 ft from the ground.andisblue said:Another thought (if preset), would manual mode have uncapped my descent rate?
Nothing the OP did is in violation of the FAA regulations.QYV said:OP doesn't have a location listed but assuming he's based in the US I don't believe we should give advice to people regarding flagrant, irresponsible violations of the law, other than to not do that when they fly. Look I'm no angel, way out in the country or woods I don't necessarily stay at 400' but even I've never been over 650' (200m). Heights like he described are reckless and dangerous and simply shouldn't be done you are well into aircraft airspace. that's all the device this OP deserves imo.
SteveMann said:Nothing the OP did is in violation of the FAA regulations.
I'd say what they s childish is just taking a drone up in FAA airspace and then loosing control.... Or what would u call thatSteveMann said:Wow, the childish name calling here is absolutely unbelievable. And un-deserved. Are there any grown-ups left here??
Please, people - GROW UP!
badbrad97 said:I love the way everyone jumps on the kid for being stupid and reckless, but i have asked this question several times before with no answer.
Can you use CSC to drop safely to a lower altitude and recover?
Let's put it into terms that all you "by the book, never break a rule pilots" will understand.
Lets say you are safely flying at 400 feet and your genuine DJI battery suddenly drops from 50% to 20%. You start to descend and can do the math and there is no way that you will safely reach the ground at the rate the battery is dropping.
Do you let it run out and crash or do you use CSC?
I am sure someone has done it...
Hughie said:SteveMann said:Nothing the OP did is in violation of the FAA regulations.
What is it about the OPs post which makes you think that his activities come under FAA regulations ?.... Unless the meaning of the word Federal has now changed ?
That is a big stretch that you can pin point his location based on one letter. You should see how many people spell like that in the UKlandmannnn said:Hughie said:What is it about the OPs post which makes you think that his activities come under FAA regulations ?.... Unless the meaning of the word Federal has now changed ?
landmannnn said:He has used US English spelling in another post.
Absolutely. It gets on my tits.landmannnn said:Does anybody else find it interesting(boring) that forums are full of amateur lawyers..
This isn't the worst, but getting there.
Hughie said:badbrad97 said:I love the way everyone jumps on the kid for being stupid and reckless, but i have asked this question several times before with no answer.
It looks as if you need about 100' after the motors have started up to arrest the rate of decent. Some idiot tried this over a residential area after climbing to 6000' on you tube.
