flashing phantom 2 vision plus
I'm having problems programming the module, I connected everything perfectly, I tested and I get the wording "BOOTME BOOTME" when I go to flash I get a loop error ""Waiting for the DM36x...
Target: BOOTME
BOOTME command received. Returning ACK and header...
ACK command sent. Waiting for BEGIN command...
Target: BOOTME"" many recommend deleting the nand with the command sfh_DM36x.exe -nanderase the problem is that cmd tells me it is a command that doesn't exist, please help me I'm trying everything to make it work
Target: BOOTME
Its fooked well and truly, there is no fix for this except for buying a blank NAND chip and reprogramming it from scratch.
Reactions: Mark The Droner
can you change just the nand chip?
He could, but to flash a chip from scratch is a lot of work, you need a bootloader installing that will boot the chip in order to be able to access it, its doable according to the dji wiki but not something for those not familiar with doing it
Potrebbe, ma flashare un chip da zero è un sacco di lavoro, hai bisogno di un bootloader che installi che avvii il chip per potervi accedere, è fattibile secondo il wiki dji ma non è qualcosa per chi non ha familiarità con questo.
Isn't there a file that can be copied and placed on the NAND chip? or do we need a way to make this work?
From memory its 3 files , a boot loader the main file and another one, take a look in the WIki page for full instructions
or search the thread started by QuadDamage for a full post about repairing it from scratch
Hi can you buy a programed wifi and video module If so how much in Canadaian
Yes, they're on eBay for around $100 USD. Make sure the seller assures you it works before you buy. Return if it doesn't work, get a refund.
Usachman
