External GPS Antenna on Phantom 2V+
Thanks for your reply. Prior to your post I ordered a 9531126-ND. After doing so I read the spec. sheet and that unit was to large. Had to reorder the 9531026-ND. Now if I can get it installed with out screwing anything up will be in good shape.
Thanks again for your post
that one works ,, not to big both are 4mm
im wrong I thought you had ordered the 931-1126-nd
The 953-1126-ND patch is 25mm x 25mm x 4mm. (To Big)
The 953-1026-ND patch is 15mm x 15mm x 4mm.(Correct fit)
Don carlos
