Extender and log info
Thanks everyone for all the help I finally got a range extender just the one that goes over your stock antenna on the standard remote it worked further then before but not much.. I also will show a screen shot of the emu error I get before I receive satellites and I only get 7 or 9 satellites but here's everything I have I hope this helps everyone to help me decide if I should send it in or get a replacement...
Just want to know if that's normally how far the PS3 goes and if I should replace or return it
I think the P3S has a longer range in perfect conditions, but you are flying in a congested urban area. You should expect much less than the max.
This is true of any of the models.
Also, maybe post this in the P3S forum instead of here in the Pro/Adv forum. The folks who read the P3S forum may have better info for you.
Good luck.
Reactions: JoBe
I've got a range extender for my Inspire 1 Pro and it helped only by 300-400 feet. The one for my Mavic actually gave worse results than without it.
robvalduga
