easy to install in phantom 1.1.1?
I have never soldered before I opened up my V1.1.1 and installed the Fat-Shark Predator. It's easy! Find the accessory wires and connect them. I connected them to a quick clip so I could attach/detach as needed.
Awsome ill look into that right away ! Thanks
Im excited about the fpv.
Whats the range like?
While I've been disappointed with the reliability of the FPV monitor on my P2V+, my P1 live feed to the Predator is fast enough to fly the aircraft and never drops off. I haven't really tested for range but probably about 400-500 meters.
Thats awsome range i had thought the 240mW transmitter with the fatshark only went 100-200 meters.
Ive seen the 580mW upgrade chip on amazon so i was doubtful on the range.
Thanks again for the cheapest link ive seen yet.
I get 1.8km (and more but I didn't have the guts to go any further) with a standard Fatshark Predator V2 + a cheap 3$ panel antenna. With the stock whip I get around 1.6Km.
Highly recommended!
[youtube]https://www.youtube.com/watch?v=NP0sNTf_AKs[/youtube]
Sorry I didn't record the FPV (dvr still on the boat from china) but you get a good sense of how far 1.8Km is. The FPV remained completely sharp and stable during the entire flight. I flew at 50m high.
can you post a pic of your setup// thanks..
just added another p1 to my fleet and I'm gonna mod this for fpv flights only I'm curious to see how you ran the wires and what you conntected to . also where you mounted the camera
I've sold my P1 and replaced it with a P2, with the same setup for the transmitter. On the P1 I used the fixed mount for my GoPro (no gimbal), but otherwise everything else is the same.
where did you get power for the TX from on the p1?
the go pro or balance port on battery or internal board?
Internally. I seem to remember two grey wires for accessories. This also powered the GoPro.
