Dyed my front props red.
Re: Dyed my front props red.
TMAN1985 said:
Marlin009 said:
If you leave them in long enough you can get black.
Those look good
Thanks. I like how they turned out.
will the hot water distort the props ? Have you tried balancing them afterward ?, I'm afraid to dunk my New props in hot water.
It did not seem to have any effect. I did check the balance after and they were fine.
I didn't use boiling water, pulled it off just before. I did mine outside and it was 55 degrees so it was well below boiling.
That probably made it take longer but no big deal. My yellow ones took 45 minutes.
I did mine inside put them in water after it was boiling. I balanced the props and it has no effect.
MS60
