Big Chips said:can some one that has done this post a step by step post..
much thanks!![]()
Big Chips said:why not?...i am not a fan of limits myself...so if it can be done...i would like to know how...not saying i would but i may or might want to later on...
MikesTooLz said:What limits? are you talking about the violation of FAA rules and putting people in risk by flying near airports?
DrJoe said:DJI updates the NAZA with their assistant software. That is the software you use to connect the computer to the Phantom and update the firmware. They only provide the latest software (usually) for download. So all you have to do is download an older Assistant software. Any Vision firmware (there are 3 versions) will fly your P2V+.
Forum member gunslinger has 1.08 and other earlier Vision software downloads here:
http://droneslinger.com/software.html
Download the one you want. Many forum members like 1.08 because it seems the most stable and is "pre" flight restrictions. All the telemetry still works. Version 3 (current) has some issues with GPS and compass synch. Its a little wobbly. You can get 1.08 here: http://www.droneslinger.com/software/assistant-1-08.zip
Just download it, run it and connect to your Phantom to update the firmware. Boom.
MikesTooLz said:Big Chips said:why not?...i am not a fan of limits myself...so if it can be done...i would like to know how...not saying i would but i may or might want to later on...
BenDronePilot said:... Bottom line is the end user needs to have the option of disabling the new fly safe feature at their own discretion and when appropriate.
DrJoe said:Just because your car can go 150mph, you don't. And having it limited would be stupid and restrictive. I don't want the restrictions, so I fly 1.08. Restricted or not, do the right thing when you fly. See the FAA fact sheet about UAS was released in January here:
http://www.faa.gov/news/fact_sheets/new ... wsId=14153
Model aircraft guidance circular:
http://www.faa.gov/documentLibrary/medi ... /91-57.pdf
If your going to fly over a large, populated area or somewhere that there are security concerns (Manhatten, DC), please speak with authorities first. These things crash and fail/fall significantly. They are not safe enough to do so without engine redundancy and control redundancy. I don't want one falling on a 3 year old.
I am a licensed pilot as well as a HUGE phantom fan & pilot. Small aircraft (including ultralights without a cockpit) can fly in class G airspace (0-700 feet uncontrolled airspace) regularly, the same airspace we fly our phantoms in. If one of our phantoms gets smacked by a Cessna going 110 knots or an ultralight pilot doing 60 knots, the results could be disastrous and deadly. You will have damaged property and possibly killed someone, along with our awesome hobby. If you don't think a Phantom can hurt a plane, your wrong. I've seen small aircraft brought down by a bird-strike with a seagull.
I have my firmware set on a maximum altitude of 121 meters (400 feet). If my phantom is ever involved in a collision, the firmware will prove I was within the FAA guidelines. I also maintain LOS (line of sight) at all times. If I am flying FPV, I have a spotter maintaining LOS for me. I stay away from people. I don't loiter over private houses without speaking to the owners beforehand. I don't sell my videos (though I should be able to). Lastly, I try and do no harm.
The NAZA flight controllers are awesome, but they are not FAA certified and could fail at any time. So are the DJI motors. An out of control Phantom coming down onto a highway and causing a traffic accident or into a crowd of school children is not unimaginable (see all the flyaway videos). Cities are not the place to fly these things. If you do, you are taking a lot of risk; you will be liable for the damage or injuries you cause, and you will have given our hobby a BIG black eye.
If you want to go higher, I suggest three things to be as safe as possible: a spotter looking for other aircraft, a call to local flight controllers to let them know where and when you will be operating (skydivers do this all the time) and have a transceiver capable of transmitting on UNICOM or MULTICOM (122.700 mHz/ 122.900 MHz) to announce your intentions while you are flying. You can speak to the pilots at your nearest airport and find out what frequency they commonly monitor. I recommend a Yaesu FTA-230 available here: http://www.sportys.com/PilotShop/product/17733
One day, a really cheap ADS-B transponder will be available, along with a logic board to avoid other aircraft with ADS-B transponders. Until then, you are flying blind and a danger to airmen if you bust 400 feet or go out of LOS. Period. Just because my car can go 170mph, it doesn't mean I drive at 170mph. While my Phantom can reach 2000 feet, it doesn't mean I'll ever fly it that high. Those idiots flying through solid overcast on YouTube are going to kill someone.
Whatever firmware you use, don't be stupid..
